3750 on Stack
cris_jimenez
Level 2
Level 2
I'd like to know if Cisco supports multiple images on a 3750 on stack
if it's supported we'd like to load
ip services on the core switches (2 switches)and ip based on the remaining switches 4
if that is supported could you please provide a link that will show us how to do you upgrade of the images on the stack
thank you
Richard Burts
Chris
I do not believe that it is supported to do what you suggest in running different images of members of the stack. In the stack all members must run the same image. If a switch is not running the same image as the master then the switch will not become an active member of the stack.
Rick
Rick
Richard Burts
Chris
Rick
Rick
thank you very much for the prompt reply Rick
That's all I needed to know
Chris
I am glad that my answer was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read a response that resolved the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Rick
Joseph W. Doherty
"I'd like to know if Cisco supports multiple images on a 3750 on stack "
Believe it is, but much depends on how the images differ.
"ip services on the core switches (2 switches)and ip based on the remaining switches 4
if that is supported "
Believe you could. You could flash each switch independently, and with compatible versions, stack them. Or you could flash one stack of two and one stack of four and join them. What's the problem, don't believe you can easily flash the combined stack of six and have two different images. (On-going upgrade headache.)
Below are two references to 3750 stack management.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#election
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00808e0604.html#wp1189523
PS:
Believe the rules of different feature sets within a stack are different for the 3750-E series.
