Cause code on AS5350 gateway
Feb 14th, 2008
When I sent the VoIP call to AS5350(IOS12.4), I always got "Disconnect Cause=1" if the T1/E1 circuit is down. So that the VoIP softswitch got "unallocated number" which is wrong.
I tried cause-code legacy but it does't help. Any advice would be appreciated.
paolo bevilacqua Thu, 02/14/2008 - 14:19
  • Hall of Fame,
    Founding Member
Well, the thing is that from the as5350 perspective, once a DP is down, all the numbers that have destination-pattern in there become unreachable, hence unallocated, or unknown to the gateway.
You can try setting a voip DP with less preference, and non existent session target. The cause code will change then.
