PIX Multiple Inside Config
r.lusignan
This should be straight forward, but for some reason I'm missing something. I have a PIX with 6 interface
E0 Outside
E1 Inside
E2 DMZ
E3 Guest
The Guest interface is the guest VLAN for the company and I want to allow access to the Internet while blocking all of our internal stuff. Sample config is here:
int e0
nameif outside
ip add 1.1.1.1 255.255.255.0
security-level 0
int e1
nameif inside
ip add 10.10.10.1 255.255.255.0
security-level 100
int e2
nameif dmz
ip add 172.16.1.1 255.255.255.0
security level 50
int e3
nameif Guest
ip add 192.168.1.1 255.255.255.0
security level 90
nat (inside) 1 0 0
nat (Guest) 2 0 0
global (outside) 1 1.1.1.2
global (outside) 2 1.1.1.3
access-list Guest_out permit ip any any
access-gr Guest_out in interface guest
Based on the config above, that should be enough to have the Guest vlan traffic PAT to 1.1.1.3 and have no issue going out?
Am I missing something?
7 Replies 7
acomiskey
Level 10
Level 10
Typo maybe, capital "G" in guest.
access-group Guest_out in interface Guest
acomiskey
Level 10
Level 10
Typo maybe, capital "G" in guest. Although that would not have prevented you from getting outside.
There isn't any issue with Typo...the config is absolutely good and would allow all IP traffic from Guest to go outside patting to 1.1.1.3
are you facing any issue ?
Actually there is a typo. And as I said, it would not have effected his ability to go outside.
Yes I am, return traffic is not being permitted back in. I can see the xlate going through ie:
Built ICMP connection for faddr x.x.x.x/0 gaddr 1.1.1.3 laddr 192.168.1.x
That outside IP i'm pinging is a router which is running debug ip icmp. I can see the source address of the ping as the global PAT'd address on the Firewall. So the config looks good, return traffic is not getting back through. The ACL on the outside interface shouldn't be blocking the traffic as it was sourced from inside..
That is not the case with icmp. You must allow it in your outside acl on the firewall.
This also serves as proof there was a typo, as he would have had to allow icmp as well in his Guest acl.
add a line permit icmp any any echo-reply on the outside access-list, if not then create one access-g on outside permitting icmp echo-reply
you are correct firewall doesn't block traffic initiated from inside, however this is ICMP, firewall treats it stateless protocol and consider the return echo reply as different connection
They fixed this issue in code 7.0 and above with "Inspect Icmp" feature
