lamav Thu, 02/14/2008 - 13:15
  • Blue, 1500 points or more
Hi:
OSPF will definitely treat the EtherChannel as a 3 Gbps link and calculate the Cost accordingly.
Remember that OSPF calculates Cost based on a reference bandwidth of 10 to the 8 (100 million)/configured bandwidth. So, a 100 M FDDi connection defaults to a cost of 1. Anything higher than that will still default to a cost of 1 (since you cannot have a fractional Cost) and nothing will be gained by havin gthat extra bandwidth configured for the interface.
So, to accomodate high-speed links above 100M, use the 'auto-cost reference-bandwidth command while in router configuration mode or use the 'ip ospf-cost' command at the interface to hardcode the Cost.
VL
cisconoobie Fri, 02/15/2008 - 07:03
I set the auto-cost reference bandwidth to 1000000 for future 10Gbps upgrades and the costs dont add up.
What would the formula be for the 3Gbps connection?
1,000,000/3,000 ?
lamav Fri, 02/15/2008 - 08:23
Hi;
The formula that Cisco's OSPF implementation uses to determine a link's Cost is 100,000,000 (100M)divided by the reference bandwidth. You have typed 1 million divided by the reference bandwidth.
lamav Fri, 02/15/2008 - 09:34
edison:
Good catch. I didnt read his post the way you did. I though tthe final reference bandwidth he configured was 1,000,000 (1M), I didnt think that he may have actually entered "1000000" as the argument in the command itself.
Maybe that's what he did....
