LAn AnD DSL On single system with cisco Router
Feb 14th, 2008
I need help immediatly within hours,anyone pls help.
In our office we have Cisco 2800 series router with two fast ethernet and two serial interfaces.
one fast ethernt inteface with ip 10.11.0.1 is connected to unmanagable 8 port switch,one port of that switch is connected with single pc which has ip
10.11.0.10 and gateway 10.11.0.1.
2nd fast ethernet interface is free.
one serial port is used for DXX circuit for connectivity between our two ofices.
other serial interface is free.
Also we have 1 Mbps DSL internet with ip 192.168.1.2 and gateway 192.168.1.1.
With current configuration i can connect to other office via dxx circuit.
HOW CAN I USE DSL ON ROUTER OR PC SO THAT I CAN ACCESS TO MY OTHER OFFICE AS WELL AS ON THIS DSL INTERNET ON SINGLE PC AT A SAME TIME.
Pavel Bykov Thu, 02/14/2008 - 13:25
  • Silver, 250 points or more
Set up NAT to the internet and make sure routing table is populated correctly. It should work
