Jabber on all phone ports
Feb 14th, 2008
All of my 3560 ports connected to phones (7940/42/60/70/71) are showing continuous 50pps output towards the phones. I've turned off GARP but still no improvement.
Although most of these phones have PC's attached, the data VLAN is not affected.
I can't get an ethereal until tomorrow but on the off chance anyone has seen this before ?
Here's a sh int from an affected interface :-
FastEthernet0/7 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 001d.e516.6109 (bia 001d.e516.6109)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:50, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:00:01
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 90000 bits/sec, 51 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
104 packets output, 22640 bytes, 0 underruns
Appreciate any ideas.
TIA.
vjemin Fri, 02/15/2008 - 06:52
I had the similar problem like you now.
The problem was in Microsoft Load Balansing.
The Microsoft guys have tried to do load balansing but it didn't work and there was a lot of multicat packets in that VLAN.
After we have removed these servers, everything was OK.
Maybe this can help you?
Vlaho
