BGP route dampening
Answered Question
Feb 14th, 2008
  • Green, 3000 points or more
Can anyone work out what I am doing wrong here. I am sure that it is obvious, but I just cannot see it:
<code>
router bgp 300
no synchronization
bgp router-id 172.16.103.1
bgp log-neighbor-changes
bgp dampening route-map BGP-damped
network 172.16.13.0 mask 255.255.255.0
network 172.16.31.0 mask 255.255.255.0
neighbor 172.16.31.1 remote-as 100
neighbor 172.16.31.1 transport connection-mode active
neighbor 172.16.31.1 update-source FastEthernet0/0.10
neighbor 172.16.36.6 remote-as 600
neighbor 172.16.102.1 remote-as 300
neighbor 172.16.102.1 update-source Loopback103
neighbor 172.16.105.1 remote-as 300
neighbor 172.16.105.1 update-source Loopback103
no auto-summary
ip prefix-list BGP-damped seq 5 permit 172.16.21.0/24
ip prefix-list BGP-damped seq 10 permit 172.16.22.0/24
route-map BGP-damped permit 10
match ip address prefix-list BGP-damped
R3#show ip bgp dampening
% dampening reconfiguration in progress for IPv4 Unicast
Jan 5 23:49:54.144: %BGP-3-BADROUTEMAP: Bad parameters in the route-map BGP-damped applied for Dampening
</code>
Kevin Dorrell
Luxembourg
Correct Answer by dongdongliu about 9 years 5 months ago
Hi,kevin
prompt:
% Bad parameters in the route-map BGP-damped applied for Dampening
because of there is no dampening parameters in the route-map BGP-damped
set some parameters like half-life , penalty to start reusing a route , penalty to start suppressing a route , Maximum duration to suppress a stable route
Correct Answer by Danilo Dy about 9 years 5 months ago
Hi Kevin,
Let me try...
I think because the route-map is "permit" which means those prefix-list will be included in the dampening, but there is no set parameters for it. For deny, it's okay without set parameters.
i.e.
set dampening [half-life] [penalty-reusing] [penalty-suppresing] [duration]
Dandy
Correct Answer by bmcginn about 9 years 5 months ago
Hi Kevin,
Mate, I think you may have to set the dampening parameters in the route-map.. I may well be wrong but thats all I can think of...
try this:
set dampening 15 750 2000 60
exit
where 15 is the half-life decay time
and 750 is the re-use time of the dampened route
and 2000 is the value when the route starts dampening
and 60 is the max time (in mins) to suppress the route...
You probably know that.. buts its friday arvo and i'm procrastinating..
Hope that answers your question...
Brad McGinn
Australia
Overall Rating: 5 (3 ratings)
Correct Answer
bmcginn Thu, 02/14/2008 - 22:14
  • Bronze, 100 points or more
Hi Kevin,
try this:
exit
Brad McGinn
Australia
Kevin Dorrell Fri, 02/15/2008 - 12:17
Absolutely right, all three of you, and all within 10 minutes of each other! I put in the "set deampening", and it all started working. Thanks.
So, to my surprise, this is one use of a route-map where it will not take the default values. I guess you use the route-map version of dampening when you want to dampen selectively, and maybe with different parameters on each prefix.
Thanks again
Kevin Dorrell
Luxembourg
Correct Answer
Danilo Dy Thu, 02/14/2008 - 22:18
  • Blue, 1500 points or more
Hi Kevin,
Let me try...
i.e.
Dandy
Correct Answer
dongdongliu Thu, 02/14/2008 - 22:50
Hi,kevin
prompt:
