RSTP convergence problem
matt.eason
Hi all,
I'm currently having issues regarding RSTP on a simple switch network, scenario is as follows. I have 2 switches directly connected to each other over a trunk link (dot1q). These 2 interfaces have the following identical config.
interface GigabitEthernet0/15
switchport trunk allowed vlan 1
switchport mode trunk
switchport nonegotiate
spanning-tree cost 100.
For some reason the 2 switch aren't exchanging STP BPDUs, this has been confirmed in a debug spanning-tree bpdu receive. Configuration on both switches is default apart from spanning-tree mode rstp. Also note that VLAN 1 is the native VLAN for that trunk, I thought that a STP instance would run for VLAN 1.
Show spanning-tree shows that each switch thinks it is the root for VLAN 1 which makes sense considering they are not talking to each other. Any ideas why this is happening?
9 Replies 9
Istvan_Rabai
Level 7
Level 7
Hi Matthew,
I just can guess.
There are some high-end multilayer switches like 6500 for which the ports are layer3 ports by default.
In this case you have to apply the "switchport" command without options on the interface to put it into layer2 mode.
My other idea is: may it be that the port is in the down state? Then use "no shutdown".
At the moment I have no more ideas.
Please write me if this solved your problem.
Cheers:
Istvan
Hi Istvan,
Thanks for your reply. First of all the switch is only a layer 2 device. I can also confirm that the interface status is up. CDP can see the neighboring switch across the interface in question.
Hi Matthew,
Can you post the full running-configs of both switches here?
Please copy and paste, and do not use attachments.
Many thanks:
Istvan
Here is the running config for each switch. Please note that Gi 1/16(mgmt2) is unplugged on each switch. Hence there is only a single active connection between the 2 switches. Output has been truncated due to exceeding the forum character limit.
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname SW1
enable secret 5 --blank--
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
vtp mode transparent
spanning-tree mode rapid-pvst
no spanning-tree optimize bpdu transmission
vlan 110
name blade-center
interface Port-channel1
description EtherChannel
switchport access vlan 110
switchport mode access
description mgmt1
interface GigabitEthernet0/16
description mgmt2
interface GigabitEthernet0/17
channel-group 1 mode on
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface Vlan1
ip address 172.16.113.5 255.255.255.0
no ip route-cache
management
ip default-gateway 172.16.113.100
ip http server
ip http authentication local
snmp-server community **
line con 0
line vty 0 4
password 7
login
line vty 5 15
login
ntp clock-period 17180224
end
version 12.1
no service pad
hostname SW2
ip subnet-zero
ip ssh time-out 120
vlan 110
name blade-center
description mgmt1
description mgmt2
interface Vlan1
ip address 172.16.113.6 255.255.255.0
no ip route-cache
management
ip http server
line con 0
line vty 0 4
password 7
login
line vty 5 15
login
ntp clock-period 17180182
end
on the GigabitEthernet0/15 interfaces that the switches are connected, let spanning-tree work out the path cost so i suggest you remove "spanning-tree cost 100" because your interfaces are gig not 10mb so i dont under why your cost is 100. the cost gor a gig is 4.
also enter the command "sh spanning-tree vlan 1" on both switches so i can see the switches config for vlan 1 instance.
Franco
if you have only a single trunk link between your switches, you dont need to worry about STP. STP is only useful if you are redunant links between your switches.
Hi Matthew,
I don't see problems with your running-configs.
However, you are mentioning, that Gig0/16 (mgmt2) has been unplugged.
Could you please verify now, if the CDP neighbor relationship is still alive through the Gig0/15 ports?
I have a supposition that you may use a straight-through cable between the Gig0/15 ports, not crossover cable.
Or there may be some other cable or connector problem.
Istvan
Mohamed Sobair
Level 7
Level 7
1st point:make sure there is a connectivity between the 2 switches before going further.
2nd point: what is this? spanning-tree cost 100 ? for which vlan you are changing the cost in G0/15?
The 3rd point, there is no need to configure cost here, since this is the only interface connected to the root-bridge, it will always be elected as a root port.
Mohamed
Hi All,
Thanks for everyone's replies.
Sorry about the delay in replying to your postings. I can confirm that CDP is operating over Gi 0/15 and I can see the neighboring switch. There is no actual problem with this setup but I did want to know why no BPDU were received across this link.
Cheers,
Matt
