Question of SNMP
Feb 14th, 2008
Hi, Sir
I ask question of SNMP's OID.
Could you tell me SNMP's OID when use T1 module on Cisco 2811?
PRI1 interface side : Normal
OID:
Index number:
PRI1 interface side: Accident
OID:
Index number:
Platform:Cisco 2811
Module:NM-1CE1T1-PRI
Config:
 card type t1 1
 controller T1 1/0
 interface Serial1/0:23
Best regards.
Ryusuke.
htarra Wed, 02/20/2008 - 14:49
If you use the integer version of the OID, you must type the entire OID string (1.3.7.2.13.78.5.6,). A new SNMP OID, rhNEChassisSerialNumber, describing the Chassis serial number has been added. You can also view this information by issuing the show version command.
http://www.cisco.com/en/US/docs/security/anomaly_detection_mitigation/appliances/detector/v3.1/release/note/ApTAD312.html#wp39636
SNMP Object Navigator tools URL:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
