unable to ping inside host L2L VPN..URGENT
Feb 15th, 2008
I have configured L2L von between ASA5520 and PIX525.Both end tunnel is active but unable to ping any inside host or peer IP.I have checked the access-list and its seems ok.
sh crypto isakmp sa (ASA550)
IKE Peer: x.x.x.x
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
pdns1# sho crypto isakmp sa (PIX5525)
Total : 1
Embryonic : 0
dst src state pending created
x.x.x.x x.x.x.x QM_IDLE 0 1
Pls help me to slove the probllem
pdriscoll Fri, 02/15/2008 - 08:35
I suspect you have a NAT issue. Are you bypassing NAT for tunnel traffic?
Run "show ipsec sa" and see if you are getting packets encrypt and de-crypt on both sides of the tunnel.
