02-15-2008 12:49 AM
Hi Sir,
Below is an excerpt of CSM config:
module ContentSwitchingModule 5
static nat 202.188.1.60
real 172.21.5.60
static nat 202.188.1.61
real 172.21.5.61
serverfarm SFARM1
nat server
no nat client
predictor leastconns
real 172.21.5.60
inservice
real 172.21.5.61
inservice
probe ICMP_PROBE
Can you kindly advise how to configure the equivalent static NAT in ACE module?
I refer to the following ACE config guide:
However I still can't understand how to configure it. Using the CSM to ACE Conversion Tool available in ACE, it classifies the NAT commands as Unsupported CSM command.
Please help.
Thank you.
B.Rgds,
Lim TS
02-15-2008 02:22 AM
Lim,
you need to create a class-map for each real.
ie:
class-map real1
match source-address 172.21.5.60 255.255.255.255
Then create a policy-map for the static nat.
policy-map multimatch NatReal
class-map real1
nat static 202.188.1.60 netmask 255.255.255.255 vlan
class-map real2
nat static ....
Then apply the policy-map on the server vlan
interface vlan X
service-policy in NatReal
tadaaaaa !
That's it.
Gilles.
02-15-2008 04:05 AM
Hi Gilles,
Thanks for your reply! I understand it now. You've been very helpful in answering several of my other posts.
Will try the config next week.
Thank you.
B.Rgds,
Lim TS
02-20-2008 12:01 AM
Hi Gilles,
Your suggested configs work in my production network!
Just some minor typo error:
class ...
Thank you.
B.Rgds,
Lim TS
