Error message
Feb 15th, 2008
On our new switch:
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(40)SE,RELEASE SOFTWARE (fc3)
We are constantly getting the following error message:
-Process= "HRPC rfs request handler", ipl= 4, pid= 148 (NCS1605-3)
-Traceback= 15864E4 1588640 1588850 59C400 5A1188 5A1504 59C6E8 5A1DB0 5A1F98 59
E634 5A006C 5A073C FC2694 68B600 68C734 68C92C (NCS1605-3)
9w5d: %SYS-4-CHUNKSIBLINGSEXCEED: Number of siblings in a chunk has gone above t
he threshold. Threshold:450000 Sibling-Count:475793 Chunk:0x3335934 Name:mifs se
ctor bu (NCS1605-3)
What is the problem?
royalblues Fri, 02/15/2008 - 03:57
My advice is to raise a TAC case.
They should be able to confirm whether it is a software or hardware issue
srego4 Mon, 10/06/2008 - 08:51
Did you ever find out what this error message was?
I am getting them on a 3560 with same IOS as you mentioned - 12.2(40)SE
