Routing and Redundancy Case
Answered Question
Feb 15th, 2008
We have two links between HQ and our Branch, one is active and the second is standby and there is HSRP between the two routers connected to both links.
We want to distribute the traffic between the two links, so we decide to route some services to the standby link and in the same time if the link is down in one of the links the traffic should route to the up and running link.
These are the configuration of both routers and I'll write the problem that we faced after reading the configuration:
1- Active Router:
interface GigabitEthernet0/0
ip address 172.16.101.7 255.255.255.0
duplex auto
speed auto
standby 102 ip 172.16.101.5
standby 102 priority 200
standby 102 preempt
standby 102 track Serial0/0/0 70
interface Serial0/0/0
bandwidth 512
ip address 11.11.11.1 255.255.255.0
encapsulation ppp
ip route 10.0.0.0 255.255.0.0 11.11.11.2
ip route 10.0.55.13 255.255.255.255 172.16.101.6
ip route 10.0.55.13 255.255.255.255 11.11.11.2 2
ip route 10.0.55.16 255.255.255.255 172.16.101.6
ip route 10.0.55.16 255.255.255.255 11.11.11.2 2
2- Standby Router
interface Tunnel1
ip address 172.16.209.1 255.255.255.252
keepalive 10 3
tunnel source 10.12.55.14
tunnel destination 172.16.199.2
ip address 172.16.101.6 255.255.255.0
duplex auto
speed auto
standby 102 timers 120 121
standby 102 priority 150
standby 102 preempt
interface GigabitEthernet0/1
bandwidth 512
ip address 10.12.55.14 255.255.255.252
duplex auto
speed auto
ip route 10.0.0.0 255.255.0.0 Tunnel1
There are two IP addresses 10.0.55.13 and 10.0.55.16, in the active router we made two routes for each IP address, the first is to the standby router and the second is to the serial interface in the active router and this last route is with administrative distance 2.
The HSRP is configured between the interface GigabitEthernet0/0 in both routers.
This configuration is not working when the GigabitEthernet0/0 or when the tunnel is down.
So what is the best solution to distribute the traffic using the previous scenario and in the same time if the interfaces are down or the link or tunnel is down the traffic will route to the only working router?
Correct Answer by royalblues about 9 years 1 week ago
You need to configure something like this on the primary router
Check whether your IOS supports it
ip sla monitor 1
type echo protocol ipIcmpEcho --- this shud be your other end tunnel IP
timeout 1000
frequency 3
threshold 2
ip sla monitor schedule 1 life forever start-time now
track 123 rtr 1 reachability
ip route track 123
This will make sure the route is in the RT only when the tunnel is up
http://cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html#wp1071672
Narayan
Overall Rating: 5 (1 ratings)
royalblues Fri, 02/15/2008 - 03:32
In your case when the tunnel goes down on the standby router, HSRP woud failover but due to the dual static routes, these are sent to the standby router and get blackholed.
Though, enhanced object tracking with both HSRP and static routes can solve your problem, i would suugest configuring GLBP
Have a look here
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fb97.html
Narayan
habeeb_talal Fri, 02/15/2008 - 07:01
Thanks Narayan for your suggestion, i found it very useful for my case, but is there any other way to solve this issue without changing to GLBP, you mention enhanced object tracking and etc?
Correct Answer
royalblues Fri, 02/15/2008 - 07:32
ip sla monitor 1
timeout 1000
frequency 3
threshold 2
ip route track 123
Narayan
Amit Singh Fri, 02/15/2008 - 08:04
What is the " show standby " output currently from your both the routers.
What happens when your interface is down on the primary router? Do you have some capture of the " show standby " when your interface is down. I have noticed one thing and this is the timers mismatch between the Primary and the secondry router interfaces. Why is that so ? Please change the timers to be exact the same vlaue on both the routers. It is suggested not to change the HSRP timers untill and unless there is some requirement and has to be same across the routers.
HTH,
-amit singh
habeeb_talal Mon, 02/18/2008 - 00:48
Thank you amit, this is the show standby output:
Primary router:
GigabitEthernet0/0 - Group 102
State is Active
28 state changes, last state change 4d18h
Virtual IP address is 172.16.101.5
Active virtual MAC address is 0000.0c07.ac66
Local virtual MAC address is 0000.0c07.ac66 (v1 default)
Hello time 120 sec, hold time 121 sec
Next hello sent in 95.484 secs
Preemption enabled
Active router is local
Standby router is 172.16.101.6, priority 150 (expires in 65.904 sec)
Priority 200 (configured 200)
Track interface Serial0/0/0 state Up decrement 70
IP redundancy name is "hsrp-Gi0/0-102" (default)
Secondary Router
State is Standby
1 state change, last state change 2d21h
Next hello sent in 107.292 secs
Preemption enabled
Active router is 172.16.101.7, priority 200 (expires in 18.868 sec)
Standby router is local
Priority 150 (configured 150)
both routers have the same timers.
Narayan, your solution solve my problem so i would like to thank you for that, but i'm interested to know if there is any other solution without using object tracking?
royalblues Mon, 02/18/2008 - 00:51
Glad to hear that the problem got solved..
Unfortunately i do not see any other way of implemeting this within your network topology
Narayan
