ACE - VIP ping issue
Feb 15th, 2008
for some reason I cannot ping the VIP I configured on one ACE context.
Here is a sample of the config:
class-map match-any L4_kitrik
2 match virtual-address 10.0.0.1 any
class-map type http loadbalance match-any L7_kitrik_URL
2 match http url .*
class-map type management match-any REMOTE_ACCESS
2 match protocol ssh any
3 match protocol icmp any
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
class REMOTE_ACCESS
permit
policy-map type loadbalance first-match L7_kitrik_LBPolicy
class L7_kitrik_URL
policy-map multi-match L4_kitrik_LBPolicy
class L4_kitrik
loadbalance vip inservice
loadbalance policy L7_kitrik_LBPolicy
loadbalance vip icmp-reply active
loadbalance vip advertise active
interface vlan 100
ip address 10.0.0.1 255.255.255.0
no normalization
no icmp-guard
access-group input ALL
access-group output ALL
service-policy input REMOTE_MGMT_ALLOW_POLICY
service-policy input L4_kitrik_LBPolicy
no shutdown
I am coming from VLAN 100.
I can ping 10.0.0.1 from different devices but not 172.16.255.1. I know connectivity is ok since I am able to telnet 172.16.255.1 into port 80... ping still does not work.
Any idea?
Regards.
Gilles Dufour Mon, 02/18/2008 - 01:06
  • Cisco Employee,
change your class-map into :
2 match virtual-address 10.0.0.1 tcp any
or
2 match virtual-address 10.0.0.1 tcp eq 80
Right now I believe your icmp traffic is interpreted as http due to your policy and therefore it fails.
Gilles.
deephazz02 Mon, 02/18/2008 - 02:19
I just tried it but no luck.
I check this configuration against some other contexts configured for http loadbalancing and the other configurations were just the same.
I need to check the servers now to see wether they reply icmp packets or not.
Gilles Dufour Mon, 02/18/2008 - 02:47
  • Cisco Employee,
if you have the class-map I configured, the icmp traffic will not be forwarded to the servers.
The ace module will respond.
Share your complete config if you want me to have a look.
Also check if the ping gets to the ace module with a sniffer trace in front of the module.
You can 'monitor' the tengig interface of the module to capture a trace.
you can send me the config to [email protected] if you want to keep it private.
Gilles.
rmathiyalagan Wed, 02/20/2008 - 14:37
ICMP replies comes from the servers configured for the vip address. Check the icmp connection status to the servers and if probes configured, check them too..
