02-15-2008 04:10 AM - edited 02-21-2020 03:33 PM
hi,
I have configured L2L vpn between ASA5520 and PIX525.The probelm is whenever I try to ping from my end i.e ASA5520,at that time only tunnel is established but after 30min automatically its get down.we are unable to ping peer ip address and inside host from both end.I ASDM it's showing 0 Rx packet.what might be the issue. pls help me in this regard.
Thanx,
som
02-15-2008 08:52 PM
Som,
Try in asa5520 enable ISAKMP Keepalives, this command helps prevents sporadically dropped tunnels due to inactivity thus monitoring the peer end point.
to enable it go to the tunnel group name for your l2l configuration.
e.g.
For code 7.x
asa(config)#tunnel-group
ipsec-attributes
asa(config-tunnel-ipsec)#isakmp keepalive
threshold 15 retry 10
for code 6.x
pix(config)#isakmp keepalive 15
post results
Rgds
Jorge
02-16-2008 03:21 AM
Hi jorge,
I have given this comman at both end and still no improvement.
I have checked peer ip,pre shared key,transform set,..but no resolved yet.
kindly help me to solve this isssue..
thanks,
som
02-16-2008 10:25 AM
Som,
Check two things, Security-association lifetime setings and isak policy lifetime must much at both ends.
crypto map outside_map 10 set security-association lifetime seconds
crypto map outside_map interface outside
where x is seconds and y kilobytes , default sa lifetime is 86400 seconds or 24 hours
also check isakmp policy lifetime e.g
isakmp policy 10 lifetime xxxx , see Verify isakmp lifetime , default is 24 hours or 86400 seconds
On this link see sa lifetime info , you may need to check the gkobal policy in vpn ra as asa/pix l2l may have inherit the default ra global policy vpn lifetime of 30 minutes, see Verify Idle / Session Timeout,this settings can be change to unlimited.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#isalife
Rgds
Jorge
02-19-2008 04:51 AM
hi jorge,
many many thanx,now i am able to reach other end by pinging but now i am facing a new porb after 30min the tunnel goes down.in the remote end(pix) vpngroup x.x.x.x vpngroup x.x.x.x idle-time 1800 command is given.
i think this is the reason but i am not sure.how to resolve this issue ..
thanx,
som
