CCME and Microsoft Active Directory
Feb 15th, 2008
  • Bronze, 100 points or more
Is there anyway to relate CCME user logins and corporate directory with company's Active Directory like in Call Manager Server Versions (integration)?
Thanks for your help,
Met.
Overall Rating: 3 (1 ratings)
paolo bevilacqua Fri, 02/15/2008 - 05:48
  • Hall of Fame,
    Founding Member
Not really. Login to the phone with pin is can be controlled by the router only. Same for loggin via web to the user GUI.
You can integrate a directory service however, for that we developed a custom ASP / XML service that pulls data from AD. If you're interested in that contact me at the address present in my profile.
metalium2007 Sat, 02/16/2008 - 15:20
Thank you again for your time.
There's your rating!
Met.
