SCA2 :- Error saving private configuration to persistant storage
Feb 15th, 2008
I'm re-using a SCA2, I've deleted all the old certs but when I started to add new keys I get the following error when doing a write flash.
write flash
Building private configuration...%%
Error saving private configuration to persistant storage Private configuration not saved. Last errno = 205 (Device not configured)
I've check the memory but it's only 8%,
has anybody seen this issue before.
Charlie
pknoops Mon, 02/25/2008 - 06:42
Hi Charlie,
I see you posted this a little while ago, but wanted to respond. In terms of this error message:
The tiny piece of memory allocated
to save the config is wedged.
A reboot is the only way to fix this condition.
Pete..
c.downie Tue, 02/26/2008 - 02:11
Pete,
Found the issue, its was a key that I had created but not done a genrsa. I deleted the key and allowed me to do wr mem.
Charlie
