02-15-2008 06:11 AM - edited 03-03-2019 08:43 PM
Is there a way or is it possible to bind 4 x isdn2 together? All terminates in the same router in both sites (A & B).
Just curius, I saw a written solution that says 512Kbps isdn2
Dandy
Solved! Go to Solution.
02-15-2008 06:21 AM
Yes, with the physical interfaces controlled by single dialer interface, with the thresholds configured, it will setup and teardown channels as traffic load requires.
02-15-2008 06:21 AM
02-15-2008 06:54 AM
Hi Paolo,
I thought of putting the 4 bri interface into one dialer pool-member and one dialer interface for that dialer pool. My skepticism is that each isdn2 circuit has a dialer string, won't it be a problem?
I'm still digging for docs in Cisco website :)
EDIT: Ok, I understand it know.
Dandy
