Meeting place Express 2.0 connecting to exchange
Feb 15th, 2008
i am trying to integrate my lab MPE system with exchange and failing miserably. I recieve the following message on the MPE when i test the exchange connectivity.
Error while testing Exchange config parameters status=6.
The email account i'm trying to use is all good in exchange and the ip connectivity is fine. I have packet sniffed the MPE when i try the connection, all traffic is HTTP directed to the exchange server. do i need to enable web mail in exchange for this to work ? any help would be appreciated as i'm no windows expert.
The MPE is Cisco NFR for lab deployment and comes on a vm.
markduffield Fri, 02/15/2008 - 07:49
Have you installed the outlook plugin and tested out the functionality?
We got several authentication failure errors when we used the "test" button on the MPE mail administration page.
Finally we just went ahead and installed the outlook plugin for meetingplace express, scheduled a meeting, invited some users and hit send... it worked!
We are using it here without issues but the "test" button still gives us errors... =|
goog luck
littledavewhite Fri, 02/15/2008 - 08:02
Mark
thanks for the post, no i have not ried the outlook plugin, i will try next week and let you know how i get on.
many thanks
dave white
ccie#13955
mightyking Tue, 06/10/2008 - 06:04
Select "False" for the SSL Enable in the exchange server configuration page.
