Nat Questions
Feb 15th, 2008
Hi all,
I have a problem with a router cisco 837 on my work. That is the configuration:
1 DSL Wan Interface named ATM0.1 with the external ip Ex: and NAT outside, and the ethernet interface with internal ip ex: and NAT inside.
The nat config is:
ip nat inside source list 102 interface ATM0.1 overload
ip nat inside source static tcp 8081 interface ATM0.1 8081
That's work fine if i try to connect with my browser from the external(ex: my house) to my work to the port 8081.
But, doesn`t work if i try to connect from my computer in the office using my external ip and port on the browser. URL ex: My computer have the ip
Wich are the correct configuration for that work correctly??
lamav Fri, 02/15/2008 - 09:41
Im not sure I understand what you are saying.
Are you saying that you have no Internet access through that router when you use a machine that sits on the local internal LAN?
If so, have you configured access list 102 correctly? Does it include the IP address of the machine you are using?
