R2 Channels Out of Service on Reboot
Feb 15th, 2008
I have seen a strange problem here, whenever i reboot my Router (cisco AS5400XM) with IOS 12.4(15)T the E1 channels configured for R2 are out of Service.
When confirmed the PBX side it still shows as In Service.
Any idea what the problem could be.
Paolo Bevilacqua Fri, 02/15/2008 - 08:41
  • Hall of Fame,
    Founding Member
Hi, can be a SW bug, can you try 12.4(11)XJ4 that has many bugfixes.
mohsin.kazi Fri, 02/15/2008 - 11:09
Well i would'nt have thought so, because we have 2 E1 pri one going to a Avaya PBX & the other to a BPL Tadiran PBX.
The E1 to the BPL switch goes out of service after a reboot.
Also i could see an Alarm on the controller, Receiver has loss of Frames.
Could this be because of framing set to no-crc4 ?
Paolo Bevilacqua Fri, 02/15/2008 - 11:42
  • Hall of Fame,
    Founding Member
Hi, crc4 or not, if on boot controller is down, and you can bring it back with show/no shut, it's a bug. It's not even the first time such a problem happens with cisco equipment.
mohsin.kazi Fri, 02/15/2008 - 11:47
I agree with you, however, shut/no shut doesnt seem to work in this case.
It only goes up again once i remove the ds0-group & create it again.
It really is weird!!!
Paolo Bevilacqua Fri, 02/15/2008 - 13:05
  • Hall of Fame,
    Founding Member
Even worse ...
Please upgrade to 12.4(11)XJ4 and try again.
