Cisco 3750G stack, error writing to flash
Feb 15th, 2008
I have a Cisco 3750G stack with 2 members, both WS-C3750G-24TS-E. IOS in use is 12.2(40)SE.
When trying to "copy run start" or "wr mem" I get the following errors:
3750STACK#copy run start
Destination filename [startup-config]?
Building configuration...
nv_done: unable to open "flash:/config.text.new"
nv_done: unable to open "flash:/private-config.text.new"
nv_done: unable to open "flash:/multiple-fs.new"[OK]
There is plenty of free space on the flash - I have checked on each member switch. Is this a bug in this IOS version?
AM
Amit Singh Fri, 02/15/2008 - 08:53
  • Cisco Employee,
Hi AM,
I have tried searching some bugs but only got the related one with this error for older IOS versions. This IOS is failry new. Did you try reloading the switches. I have seen in some of the previous cases that this gets correct after a switch reload.
If still it doesnot work, I would suggest you to talk to the TAC and get this resolved or see if the older bugs also exist in this new IOS or not.
HTH,
-amit singh
