ASA 5520 using Client VPN and RADIUS authentication
Feb 15th, 2008
Hi, I have a Cisco Concentrator. Users using their Cisco VPN client authenticate using RADIUS (Active Directory) which just a windows IAS server.
I eventually want to move the Client VPN's over to the ASA's but I can't find where to add the authentication servers in the ASDM?
acomiskey Fri, 02/15/2008 - 09:15
Config -> Device Management -> Users/AAA -> AAA Server Groups. Create a server group, then add a server to that group.
whiteford Fri, 02/15/2008 - 11:37
Thanks, Is that for users logging onto the ASA, or as a Cisco VPN client connection?
Also on the Concentrator there is a great monitoring tool called Monitoring | Filterable Event Log, it really helps me see why a user can't logon or a VPN Lan to Lan can connect, does the ASA have a simialr tool?
acomiskey Fri, 02/15/2008 - 11:50
It can be used for either. To use it for vpn clients, you must assign the server group to the ipsec connection profile.
Try Monitoring -> Logging -> View
whiteford Fri, 02/15/2008 - 12:28
Thanks again, don't suppose there is a migration document or any document to help me configure the client VPN's, so use to the Concentrator.
