Can't ping the interfaces of the FWSM
Feb 15th, 2008
Im working on a way to monitor our FWSM interfaces and find out that the SNMP is good way for that. Anyway, I've tried also to monitor the FWSM using ping coming from a server on the inside interface to all other interfaces with lower security level and I'm unable to do that.
The only response that i got is from the inside interface.
I already have the command "icmp permit any" in all interfaces. Do you guys know what is missing or wrong, that is causing no response from the other interfaces?
husycisco Fri, 02/15/2008 - 17:28
  • Gold, 750 points or more
Hi Marcos
Issue the following for PINGs
policy-map global_policy
class-map inspection_default
inspect icmp
Issue the following for pinging inside interface from lower sec int
management-access inside
marcospce Fri, 02/15/2008 - 18:35
I already have this:
match default-inspection-traffic
class inspection_default
inspect icmp
inspect icmp error
inspect ftp
inspect netbios
inspect rsh
inspect smtp
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect dns maximum-length 1500
service-policy global_policy global
