log partition full
Feb 15th, 2008
my c60 box, has stopped working. In the log i can see log partition is full.
With FTP connection i have deleted any .s files in directories but with the command: status detail i still see "Logging Disk Usage 106%" Is there a way to do a disk format ?
Regards.
pvdberg00 Fri, 02/15/2008 - 14:24
The best is report this to support. They have to cleanup not removed temp file. This has been filed as defect 38555.
What version of aSyncOS you are using ? Support told me that this problem is solved in 5.5.1-011.
