Ericsson PBX and E1
Feb 15th, 2008
Dear Voice eng(s)
I have one E1 link from telco to my Ericsson MD-110 PBX.
is it possible that I add a cisco VG to send data traffic over this E1?
I have read cisco documents about Er Md110 and cisco Vg but i want user data and voice traffic together on same E1
Overall Rating: 3 (1 ratings)
paolo bevilacqua Fri, 02/15/2008 - 12:49
  • Hall of Fame,
    Founding Member
Yes, connect an ISR router with vwic card 2 ports between telco and pbx, and you will be able to terminate data calls in the router, and send voice calls to the PBX.
emadehsan Sat, 02/16/2008 - 11:02
accroding the E1 line from telco is no protocol how can configuratio be?
paolo bevilacqua Sat, 02/16/2008 - 11:41
  • Hall of Fame,
    Founding Member
No protocol ? what that means? Where are you located ? E1 from telco are all PRI or R2.
