WAAS configuration with 3750 or 3560
Feb 15th, 2008
Hi, I'm trying to connect these two devices and still could not get it.
Could you please give me a hand with the wccp config?
Attached I post the switch conf, the wae conf and the deb ip wccp events output in the switch and the sh wccp routers on the wae.
Thanks very much.
Rgds.-
Esteban
bennyferber Thu, 02/21/2008 - 06:16
Hi Esteban,
change the configuration on your wae from:
wccp tcp-promiscuous router-list-num 1 mask-assign l2-return
to:
and configure on the switch on the interface that connect to the waas the command:
ip wccp redirect exclude in
to prevent routing loop.
Benny
elabraham Mon, 02/25/2008 - 12:53
Hi Benny, I made the changes you told me so, but still no connection. Indeed I've tried all possible forms, L2-redirect, L2-return with and without mask-assing and nothing. Could you tell me some other things to try, besides this I have a doubt about the router-list defined, is it suppoused to be the ip wich the WAE is connected against or it has to be the ip range wich I want to accelerate?
Thanks.
Esteban
bennyferber Tue, 02/26/2008 - 00:34
Hi Esteban,
You shouldnt configure L2-redirect or L2 return on the wae.
you should configure "wccp tcp-promiscuous router-list-num 1".
olso make sure you are using wccp v2 on the switch.
The router list should be the ip address of the router/l3switch.
Benny
elabraham Tue, 02/26/2008 - 10:52
Benny, sorry to bother you but still nothing, no WCCP L2 connection.
Attached I post the output of the wccp packets and events debug in the switch and the WAE.
Hope this could help!
Thanks a lot.
Esteban
