Routing a specific VLAN out a separate default gateway(ISP)
We have a switched network running OSPF with numerous VLANS all funneling out one default gateway for our internet/outside access.
We have had a Comcast cable modem installed to use as a separate internet gateway for Vendors and for out IT departmental testing.
I have set up a port as a router interface off a Layer 3 switch and I want to route all traffic from a specific VLAN on our campus out that interface, however, that VLAN and the routed interface is picked up by OSPF and included in the routing table. I've tried to use a route-map and tell that subnet to go out the routed interface and use the comcast device IP as it's gateway, but it's still routing the traffic internally. I'm stumped. How do I specify a separate default gateway and route for that specific traffic?
I have this configured already. What is it that I'm doing wrong?
interface GigabitEthernet1/0/16
no switchport
ip address 10.1.10.2 255.255.255.0
ip access-group 121 in
ip route-cache policy
speed 100
duplex full
no mdix auto
interface Vlan201
ip address 172.XX.XXXre.1 255.255.255.0
access-list 121 permit ip 172.XX.XXX.0 0.0.0.255 any log
route-map comcast permit 10
match ip address 121
set interface GigabitEthernet1/0/16
set ip next-hop 10.1.10.1
I've tried to type "ip policy route-map comcast" on my gig 1/0/16 interface, but it doesn't show. Am I typing it in the wrong place?
Edison Ortiz Fri, 02/15/2008 - 15:29
  • Hall of Fame,
    Founding Member
The policy must be place in the ingress interface, in your case interface Vlan201
You also need to remove the log from the ACL, not supported for PBR.
