Eigrp Load Balancing
Feb 15th, 2008
According to the info below if I disable fast switching then I'll have per-packet load balancing and if I have fast switching enable then I have per-destination load balancing right?
Per-destination or per-packet load-balancing depends on the type of switching scheme used for IP packets.
By default, on most Cisco routers, fast switching is enabled under interfaces. This is a demand caching
scheme that does per-destination load-balancing. To set per-packet load-balancing, enable process
switching (or disable fast switching),
Overall Rating: 3 (1 ratings)
