Load balancing - failover one router and two 6509s
pat.clements
I have a 7206vxr running ver 12.4(9) with a ip 10.10.1.5. And two 6509's running 12.2(18). What I am trying to do is: on the 7206 have gig0/1 go to 6509-1 and then have gig0/2 go to 6509-2.
On the 6509-1 I have:
-channel 1
switchport
switchport trunk allowed vlan 1-100Port5
switchport mode trunk
Gig 8/1 & gig 9/1 are in port-channel 1 to 6509-2
Interface vlan 1
ip address 10.10.1.2/24
glbp 1 ip 10.10.1.1
On the 6509-2 I have:
interf vlan 1
ip address 10.10.1.3
glbp 1 ip 10.10.1.1
interface port-channel 1
switchport
switchport trunk allowed vlan 1-1005
How do I make a single ip address 10.10.1.5 on the 7206 failover or load balance to the 6509's?
Thank you for your help, Pat
steven.henson
Does the 7206 allow you to group the ports in an etherchannel. I so you could load balance between device.
Hope this helps, Steve
Joseph W. Doherty
What you seem to trying to do is treat the two 7206 routed ports like your 6509 switched ports; don't believe it can be done.
If the 7200 offered switched ports, like those on the switch port cards of the ISRs, you could.
Otherwise, you'll need to define the two 7206 interfaces as different subnets. If you can run routing on your 6509s, you can then load balance across the routed links.
dongdongliu
hi,Pat
I`m not sure I understand your mean, if you want to use like "Y" cable between 72 and two 65 with L3 interface, this is impossibility. but, route protocol will make L3 path redundancy and LB working well.
good weekend
