02-15-2008 09:54 PM - edited 03-05-2019 09:11 PM
Hi Netpro,
We are currently setting up a router to get a DHCP address for a WAN interface, is there any particular option that must be enabled for this to happen ?
02-16-2008 12:58 AM
config t
service dhcp
int
ip address dhcp
Narayan
02-16-2008 08:10 AM
As Narayan indicated, ip address dhcp will obtain the IP address from DHCP server. However, if you are using the PPP encapsulation in the interface (PPPoE or PPPoA), you may need to use the ip address negotiated
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hdia_r/dia_i1h.htm#wp1184978
HTH,
__
Edison.
02-16-2008 01:48 PM
This interface will be supplied a address via a DOCSIS2.0 Modem, which command should I use ?
