IDSM-2 SPN port config
Hello:
I am in the process of setting up the IDSM-2 and little confused on setting up the monitoring ports...According to the guide...
the source port is settup as:
router(config)# monitor session 1 source interface GigabitEthernet2/10 both
the SPAN destination is setup as:
router(config)# monitor session 1 destination intrusion-detection-module 9 data-port 1
Now, how do I configure the SPAN to monitor only a selected VLANs? and the direction (rx, tx, both) to monitor?
Thanks in advance
hoffa2000 Wed, 02/20/2008 - 01:57
Use the command monitor session 1 filter vlan xx to only include the VLANs you want to monitor. Regarding the direction of traffic, RX TX or both is set on a per interface basis so in your case you can't set up source g2/10 to VLAN 2 rx and VLAN 3 TX at the same time.
Hope this helps
/Fredrik
