Gateways
Answered Question
Feb 16th, 2008
Hi All,
Can you please explain the difference between the Q921 and Q931 debugging in Gateway.
Correct Answer by Paolo Bevilacqua about 9 years 1 month ago
Q921 is isdn layer 2, an hdlc-family protocol that ensures messages are reliably sent between router and switch.
Q931 is isdn layer 3 and is used to for the actual call messages, o top of layer 2.
Depending on where you suspect the problem is, you enable one or another, sometime both.
Overall Rating: 4 (2 ratings)
Correct Answer
Paolo Bevilacqua Sat, 02/16/2008 - 03:17
  • Hall of Fame,
    Founding Member
