downgrade cme gui
cfajardo1_2
if i uploaded cme-gui-4.1.0.2 on my 2801 and decided to load cme-basic-3.4.0.0, do i still require to load a 3.4.0.0 gui?
if it realy requires, can i upload the new gui without deleting the previous gui's?
thanks
14 Replies 14
paolo bevilacqua
Yes. You can copy the files in a different directory and specify it with "ip http path".
iam new in this and everything is configured on the root directory. I have cme/cue on the same box. If we can just identify the files for the cme gui so i could just delete them before uploading the other.
Example for 4.1. But as I said before, you copy the other files in a different directory, no need to delete anything, and easier to switch back.
CME#dir GUI
Directory of flash:/GUI/
35 -rw- 653758 Nov 15 2007 12:05:18 +01:00 admin_user.js
36 -rw- 16344 Nov 15 2007 12:05:18 +01:00 dom.js
37 -rw- 864 Nov 15 2007 12:05:20 +01:00 downarrow.gif
38 -rw- 6146 Nov 15 2007 12:05:20 +01:00 ephone_admin.html
39 -rw- 4658 Nov 15 2007 12:05:20 +01:00 logohome.gif
40 -rw- 3724 Nov 15 2007 12:05:20 +01:00 normal_user.html
41 -rw- 80033 Nov 15 2007 12:05:22 +01:00 normal_user.js
42 -rw- 843 Nov 15 2007 12:05:22 +01:00 sxiconad.gif
43 -rw- 2410 Nov 15 2007 12:05:22 +01:00 telephony_service.html
44 -rw- 870 Nov 15 2007 12:05:22 +01:00 uparrow.gif
45 -rw- 9968 Nov 15 2007 12:05:24 +01:00 xml-test.html
46 -rw- 3412 Nov 15 2007 12:05:24 +01:00 xml.template
47 -rw- 4627 Nov 15 2007 12:05:10 +01:00 admin_user.html
48 -rw- 1029 Nov 15 2007 12:05:18 +01:00 CiscoLogo.gif
49 -rw- 618 Nov 15 2007 12:05:18 +01:00 CME_GUI_README.TXT
50 -rw- 953 Nov 15 2007 12:05:18 +01:00 Delete.gif
51 -rw- 1347 Nov 15 2007 12:05:22 +01:00 Plus.gif
52 -rw- 174 Nov 15 2007 12:05:22 +01:00 Tab.gif
if u can show me how to do that. And what will happen to my cue gui if we are going to proceed as you have instructed
mkdir and copy in there.
Spcify the path as mentioned above.
That's it.
ive installed cme 4.0 on a directory called CME. The gui works but when i check the ABOUT menu, it shows blank. whats wrong?
ive invoked the ff
ip http path flash:/cme
Hi, the gui does many things strangely and some doesn't do at all. if is not crucial to you, don't worry about.
so how would i know now whether iam using the files under the main dir of my flash or the one ive newly created
Move the previous files from root to another directory (rename command works), this way you will be sure.
i dont want to do that coz there are lot of files under the root. i just want to know which directory my CME has taken.
thanks
Well, if you look in one of my replies above you will see which files need to be moved. Now since I'm not sure tha root can be excluded from http server path, I think you need to reorder your flash anyway.
i think its better like just to see what version of CME my routr is running now. I cant see any command to show that.
Show telephony-service
thanks a lot
