Reg:l3 suitable switch
dhanikonda
Dear sir,
L3 switch with 24 Nos. 10/100 base-T RJ 45 ports and 2 Nos. single mode 1000 base Fiber LX full duplex port modules (for incoming and 1 outgoing fibre cables), Mounting Rack ,suitable power socket, complete as per latest specifications . POE enabled or external power.
srini
5 Replies 5
royalblues
Level 10
Level 10
Go for WS-C3560-24PS-S
It has 24 10/100 ports and 2 GBIC slots which can be populated with SFPs for terminating 1000base LX . It is also POE enabled
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7f.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
If you do not require POE, you can go for
WS-C2960-24TS-S
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
Narayan
Dear royalbles,
Thanks for ur reply one more small doubt
ws-c3560-24ps-s will Configurable upto 16000 mac addresses
regards
srini
Srini,
The 3560 supports 12000 mac addresses...
refer the link to the data sheet above
Narayan
WS-C2960-24TS-S
It fails the Layer3 requirement :)
__
Edison.
Thanks for correcting Edison...
i missed the first line completely :-)
Narayan
