SHUTDOWN
vishvajeetsingh
COMMAND TO SHUT DOWN ROUTER
6 Replies 6
Danilo Dy
There is no command to shutdown a Cisco Router or Switch.
Dandy
Edison Ortiz
If you want to shutdown a router (don't understand the reason for that, but anyway), then I recommend purchasing a 'managed' power supply. Remote control the power supply and deactivate the 'power port' where the router is connected to.
HTH,
__
Edison.
Personally, when a router gives me trouble, I just use a sledge hammer to shut it down. :-D
It is worth noting that the sledge hammer approach invalidates the manufacturer's warranty in almost all cases.
There is no IOS command to shut down a router. You can reload one, but you can't shut one down. You can also disable specific interfaces by using the "shutdown" command in that interfaces' configuration mode. Alternatively, if a full shutdown is needed, Cisco routers come with a power switch on the chassis.
Incidentally, does anyone know why Cisco's switches don't have an on/off switch, when their routers do?
Cheers
Graeme
Not all Cisco switches, just the access switches (29xx, 35xx and 37xx). The 4500 and 6500 have on/off button. The answer has to do a lot with cost.
__
Edison.
"The answer has to do a lot with cost."
A good sledge hammer only costs 10 bucks!
