IPCC Express AA (Auto Attendant) Script
Feb 16th, 2008
Dear All,
I need to modify the default AA Script in IPCC Express 4.0, by default the script performs these actions
Press 1 to dial your desire extension
Press 0 for the operator
Now i want to limit my DN range for option 1, i.e outside caller can only call my IP Phones from DN Range 1000-1999
only, I dont want every IP Phone to be dialed in from outside, only the given range should be able to dialin. Is there any idea how to do that ??
Abdulbaseer Mohammed Mon, 02/18/2008 - 13:01
you can do this number of ways. If you want to keep 1 and 0 you can do that as well or you can send callers srtaight to option 1 and ask for extension number.
When they input extension you can check the input value if less than 1000 or more than 1999 you can error out else continue to transfer the call.
