Correct Answer
Edison Ortiz Sat, 02/16/2008 - 16:49
  • Hall of Fame,
    Founding Member
BootStrap is on the chip and firmware isn't available for upgrade. You can only field-upgrade the IOS.
HTH,
__
Edison.
lamav Sat, 02/16/2008 - 16:57
  • Blue, 1500 points or more
Edison, you could upgrade the SP ROMMON and RP ROMMON on a 6500 switch, though...correct?
Edison Ortiz Sat, 02/16/2008 - 20:49
  • Hall of Fame,
    Founding Member
Correct, you can also upgrade the bootloader in the 7200 router.
Joseph W. Doherty Sun, 02/17/2008 - 04:37
PS:
Since 6500s and 7200 have been mentioned, just wanted to also note I believe other newer routers also support software upgrades to their ROMMON, such as (but not limited to) the 37xx and 38xx, but not the 36xx.
PPS:
Also, other hardware within some of the larger routers and switches also support firmware software upgrades.
smitty6504 Mon, 02/18/2008 - 06:02
Edision,
Thanks. I have upgraded it on a 3845 and didn't know if it was possible to do that on a 3640. Thanks!
