Local Authorization on IOS is not working!1
Feb 16th, 2008
I am trying to configure local authorization on a router on the console access for a user with privilege 5 (the username is "test").
I have privileged some commands under level 5, however the authorization is not taking place and when the user logs in he is assigned a privilege of 15 instead of 5!
Attached is the config which I made on the router. Can somebody please assist me on this?
Haitham
royalblues Mon, 02/18/2008 - 02:21
  • Green, 3000 points or more
Can you try removing the "Privilege level 15" commnad from the VTY lines?
Narayan
