Redundency with IPSec Tunnels
Feb 16th, 2008
I need some assistance in proper;y setting up a failover tunnel on spoke connections. We have ASA's located at two separate data centers. I would like for a router @ a remote location to fail over to a separate ASA, giving the initial tunnel goes down.
I am thinking that I should utilize one of these two ways:
crypto map tohub 1 ipsec-isakmp
set peer 10.1.1.1 default
set peer 10.2.2.2
set security-association idletime 120 default
or
crypto map tohub 10 ipsec-isakmp
set peer 10.1.1.1
crypto map tohub 20 ipsec-isakmp
set peer 10.2.2.2
Is it possible and would I need to setup two RSA keys on the remote routers.
Any help would be greatly appreciated.
Richard Burts Mon, 02/18/2008 - 10:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dwayne
While both configs would be possible I believe that the first one is closer to providing the functionality that you describe of failing over to the other peer if the first one fails. The first alternative has a single tunnel and is a bit more simple. In the second approach you are configuring 2 tunnels. And they both will be active all the time.
I have done a project for a customer where we did something similar. In that case we chose to configure 2 tunnels. We also configured the IPSec VPN to run with GRE. We run a dynamic routing protocol over the GRE tunnel and the choice of which tunnel to send traffic over and the automatic detection of loss of a peer and failover to the other peer is handled by the routing protocol. This works fine but it does introduce some complexities not present in the single tunnel approach.
Rick
iraban Tue, 02/19/2008 - 06:44
Its not RSA keys that you define, its preshared key.
you can define 2 peers in just 1 statements, if peer 1 cannot be contacted then it will try and negotiate phase 1 with peer 2 , you can define upto 5 peers (i believe)
depending on how your routing is setup you might also need to add a floating static for the peer 2.
dphills18 Tue, 02/19/2008 - 12:33
Thanks for all the replies.
I was talking to a guy from Cisco and he told me that the first one is the best, but i need to make sure that each ASA has the same root certificate.
Does anyone have any insight on this.
