Configure WIC Adsl in corporate router for Internet connectivity
Feb 16th, 2008
I have the following scenario:
We have a Cisco 2811 router in my HO which is used for corporate data network.
All the branch offices connect to this router through an MPLS data network.
Now, I would like to give some of the users access the Citrix Web interface.
I will add one WIC ADSL in the 2811 router for this purpose only, which
will be connecting to internet. It has public IP also.
Now, How do i configure the 2811 router to address this scenario? How do I give access the internet users and corporate users to the server (citrix) without changing the default gateway of the webserver?
Please provide me a step by step configuration to setup the WIC and routing as i dont have enough experience in Cisco
Thanks for any input.
Paolo Bevilacqua Sun, 02/17/2008 - 03:35
  • Hall of Fame,
    Founding Member
first of all, if you don't have experience in cisco, you need to hire someone that does, else it will be very difficult for you to get it working.
Then, on the router connected to the internet, you forward some ports to the internal server. And the default gateway of it, must have default route to said internet router.
In any case, write back when you have the hardware and the circuit working.
basheerpt Sun, 02/17/2008 - 05:02
Thanks P.B,
I have working knowledge on cisco routers but when it comes complicated configurations I need a push.
The WIC ADSL is inserted and shows OK, Please advise what to do next, as mentioned.
Paolo Bevilacqua Sun, 02/17/2008 - 05:27
  • Hall of Fame,
    Founding Member
Have you been given an username/password for the DSL ? Or a static address perhaps ?
basheerpt Sun, 02/17/2008 - 05:39
Yes, its done. both pap and chap has given and CD is ok.
Paolo Bevilacqua Sun, 02/17/2008 - 10:04
  • Hall of Fame,
    Founding Member
Let's try first with PPPoA that has no MTU reduction:
int atm0
pvc x/y <-- You need to know vp/vc values
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface dialer 0
dialer pool 1
dialer-group 1
ip address negotiated
ip nat outside
ppp pap sent-username xxx password zzzz
ppp ipcp dns request
ppp ipcp default route
int fa0/0
ip nat inside
dialer-list 1 protocol ip permit
ip nat inside static tcp 80 interface dialer 1 8000
Note you must be able to ping citrix from router for this to work.
basheerpt Sun, 02/17/2008 - 22:44
Hi P.b,
I already have three dialer interfaces (ADSL) which is used to connect branch offices. So should i change , dialer, pool, group numbers to 3?
Is that all configurations have i to apply? Please provide if anything left in your previous post. I am going to apply the changes and test it today evening, while the users are out.
Thanks again
Paolo Bevilacqua Mon, 02/18/2008 - 02:48
  • Hall of Fame,
    Founding Member
Where do you have the dialer interfaces ? Do you have other dsl interface in the same router ?
The config should be enough to let people acces internal web server from outside.
basheerpt Mon, 02/18/2008 - 04:35
The other interfaces are in same router. I have three dsl wics on it. The new one will be forth.
Paolo Bevilacqua Mon, 02/18/2008 - 04:52
  • Hall of Fame,
    Founding Member
So yes you need a new dialer interface to keep setting separate.
basheerpt Mon, 02/18/2008 - 05:11
Thanks, so it will be dialer3 and bridgegroup 3, right?
basheerpt Sat, 02/23/2008 - 00:56
Dear p.b,
where will i put the DNS server addresses for this internet connection? which interface?
Paolo Bevilacqua Sat, 02/23/2008 - 05:17
  • Hall of Fame,
    Founding Member
do not worry about putting any DNS server for this connection, router doesn't need DNS.
basheerpt Sat, 02/23/2008 - 07:12
The 'ppp ipcp default route' command doesnt accept in the dialer interface.
