02-17-2008 09:13 AM - edited 03-15-2019 08:52 AM
1)Limit of admin session is one by default, can i change it?
2) Where i can find CUE Admin guide
3) For notification for mobile: where i should configure the necessary css to be able to call out the mobile number
"call patern is allowed *"
Good day
Solved! Go to Solution.
02-17-2008 11:51 AM
Hi Wissam,
You are most welcome :) I did some more research on this and found that only 1 Administrator can be logged in at any given time (what you are seeing). This is not a configurable setting.
Hope this helps!
Rob
02-17-2008 10:00 AM
Hi Wissam,
#1 - I beleive you can configure SuperUsers that have Admin privledges.
#2 - Cisco Unity Express 3.1 Voice-Mail and Auto-Attendant CLI Administrator Guide
Cisco Unity Express GUI Administrator Guide
#3 - You can use the following Guides for setting up the Notification parameters;
Configuring Restriction Tables
Configuring Message Notification
Hope this helps my friend!
Rob
02-17-2008 11:03 AM
thanks a lot for your help.
for point 1,i have already configured this but once i log in with the first admin and go to the second session i get this:
" You are currently logged in without Administrator privileges, since the system has reached the maximum Administrators limit"
Good day
02-17-2008 11:51 AM
Hi Wissam,
Hope this helps!
Rob
02-17-2008 09:47 PM
thanks a lot
i though so since i looked into the admin guides i had with no success, that's why i asked for more admin guide.
again thanks a lot
Good day
