02-17-2008 02:55 PM - edited 03-05-2019 09:12 PM
I have a pair of 6509's each having a single sup720-3bxl, 6408 8port gbic, and 2 6748 modules. I am experiencing higher than expected interrupt cpu usage with about 900mbps of inbound ip traffic. I don't have dynamic routing, just a few routed vlans and a couple static routes. I am also doing hsrp for the vlan interfaces between the two. Here's some stats:
show proc cpu | exclude 0.00 :
CPU utilization for five seconds: 40%/39%; one minute: 43%; five minutes: 44%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
122 72629332 359004276 202 0.87% 0.64% 0.67% 0 IP Input
show mls stat :
Statistics for Earl in Module 5
L2 Forwarding Engine
Total packets Switched : 561152787313
L3 Forwarding Engine
Total packets L3 Switched : 559997750297 @ 179965 pps
Total Packets Bridged : 345312572741
Total Packets FIB Switched : 213554111543
Total Packets ACL Routed : 0
Total Packets Netflow Switched : 346020241
Total Mcast Packets Switched/Routed : 49412512
Total ip packets with TOS changed : 2
Total ip packets with COS changed : 2
Total non ip packets COS changed : 0
Total packets dropped by ACL : 1215
Total packets dropped by Policing : 0
Total packets exceeding CIR : 0
Total packets exceeding PIR : 0
Errors
MAC/IP length inconsistencies : 0
Short IP packets received : 0
IP header checksum errors : 0
TTL failures : 4711
MTU failures : 0
Total packets L3 Switched by all Modules: 559997750297 @ 179965 pps
show plat hard cap cpu :
CPU Resources
CPU utilization: Module 5 seconds 1 minute 5 minutes
3 1% / 0% 0% 0%
4 0% / 0% 0% 0%
5 RP 50% / 49% 46% 45%
5 SP 7% / 0% 5% 5%
Processor memory: Module Bytes: Total Used %Used
3 219980576 53867208 24%
4 219980576 53867448 24%
5 RP 928258080 72475552 8%
5 SP 902888420 144729544 16%
I/O memory: Module Bytes: Total Used %Used
5 RP 67108864 11891816 18%
5 SP 67108864 11891760 18%
I have no ip redirects, no ip unreach, and no ip proxy-arp on these vlan interfaces.
About 90% of the traffic generated is coming in via vlan500 (gige to our bw provider). Most of the traffic than flows to vlan503 (external ip's).
Any suggestions?
02-17-2008 02:59 PM
02-17-2008 03:02 PM
Whoops, forgot to mention I am running 12.2(18)SXF7.
02-22-2008 09:56 AM
Can anyone offer some insight here? Its a bit shocking that a sup720 chokes on less than a gigabit of traffic. I have very little configured on this pair, and I plan to add alot more traffic.
02-22-2008 07:30 PM
Unfortunately more info is going to be needed to lend any real help.
I agree that the CPU usage is a bit on the high side. The usual problems are spanning tree, multicast, ip unreachables, etc...
If possible take a sniffer trace of the incoming traffic to see if you notice anything out of the ordinary. Posting your config may lead to someone noticing something out of the ordinary...
02-25-2008 04:53 PM
02-26-2008 05:28 AM
Lets see the following information:
1. show ip traffic (x3 over the course of a min)
2. show proc cpu (while CPU is high)
3. show stack
Lets start with that and we can talk about getting a backplane sniffer capture after I look at the above information.
Email me directly at answanso@cisco.com.
thanks
Anthony
02-26-2008 05:43 AM
Also let me see the following command as well:
1. sh ip nat stat
2. sh ip nat tr verbose
3. show platform hardware pfc mode
4. show mls netflow ip count
Anthony
