cme: line selection failed
Feb 17th, 2008
we have a ccme with 4 analog lines (centrex) to phone co.
calling and receiving from voip phones are fine. But when user pick a line (phones shared lines and multi lines was configured for each phone) and call was made, ccme used different line number to make a call.
How can we make a call from a line which was picked.
Rob Huffman Sun, 02/17/2008 - 17:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi SR,
Have you looked into using this good CME Feature?
Automatic Line Selection for Incoming and Outgoing Calls
On multiline IP phones, lifting the handset automatically selects the first ringing line on the phone or, if no line is ringing, selects the first available idle line for outgoing calls. This is the default behavior for all multiline IP phones.
Under some circumstances, however, you might want to require that a line button be explicitly pressed to select an outgoing line or to answer an incoming call. In Cisco CME 3.0 and later, you have the flexibility to assign the type of line selection that each IP phone uses.
The Automatic Line Selection feature allows you to specify, on a per-phone basis, the line that is selected when you pick up a phone handset.
Any of the following behaviors can be assigned on a per-phone basis:
Automatic line selection-Picking up the handset answers the first ringing line or, if no line is ringing, selects the first idle line. Use the auto-line command with no keyword or argument. This is the default.
Manual line selection (no automatic line selection)-Pressing the Answer soft key answers the first ringing line, and pressing a line button selects a line for an outgoing call. Picking up the handset does not answer calls or provide dial tone. Use the no auto-line command.
Automatic line selection for incoming calls only-Picking up the handset answers the first ringing line, but if no line is ringing, it does not select an idle line for an outgoing call. Pressing a line button selects a line for an outgoing call. Use the auto-line incoming command.
Automatic line selection for outgoing calls only-Picking up the handset for an outgoing call selects the line associated with the button-number argument. If a button number is specified and the line associated with that button is unavailable (because it is a shared line in use on another phone), no dial tone is heard when the handset is lifted. You must press an available line button to make an outgoing call. Incoming calls must be answered by pressing the Answer soft key or pressing a ringing line button. Use the auto-line command with the button-number argument.
Automatic line selection for incoming and outgoing calls-Pressing the Answer soft key or picking up the handset answers an incoming call on the line associated with the specified button. Picking up the handset for outgoing calls selects the line associated with the specified button. Use the auto-line command with the button-number argument and answer-incoming keyword.
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeautol.html
Hope this helps!
Rob
smallrain_2 Sun, 02/17/2008 - 18:50
Hi Rob,
I read your in other thead and tried it but didn't work.
On phone side, it is not a problem. But router/ccme is using random lines.
Any idea?
Here is my conig:
voice-port 0/1/0
connection plar 1111
caller-id enable
voice-port 0/1/1
connection plar 1112
caller-id enable
dial-peer voice 11 pots
description EXTERNAL DIAL PEER FOR 1111
destination-pattern 9.T
no digit-strip
direct-inward-dial
port 0/1/0
dial-peer voice 12 pots
description EXTERNAL DIAL PEER FOR 1112
no digit-strip
direct-inward-dial
port 0/1/1
ephone-dn 1 dual-line
number 1111
ephone-dn 2 dual-line
number 1112
ephone 1
device-security-mode none
mac-address 001B.xxxx.xxx1
type 7931
auto-line incoming
button 1:1 2:2
ephone 2
mac-address 001B.xxxx.xxx2
type 7931
button 1:1 2:2
paolo bevilacqua Mon, 02/18/2008 - 02:42
  • Hall of Fame,
    Founding Member
which number is being used ? It has to be either 1111 or 1112 depending which line was used.
dmitrybarsky Mon, 02/18/2008 - 07:05
Try adding "preference" to your outgoing dial peers. So, in the second outgoing dial peer add "preference 1" (leave the first one alone since preference 0 is the default, I believe.
~barsky
smallrain_2 Mon, 02/18/2008 - 07:58
I have tried all I can think of, including preference. Call go out consistantly from lowest prefernce dial-peers if preference value was assigned.
That is not what I want. I want to pick a line and call out from that particular line.
smallrain_2 Mon, 02/18/2008 - 08:01
I was testing from ephone 1, which is configured with "auto-line incoming"; calls randomly go out from both. (actually from 4 different lines; I was too lazy to show/copy entire config)
paolo bevilacqua Mon, 02/18/2008 - 09:52
  • Hall of Fame,
    Founding Member
Hiw, can you post the relevant config, end explain exactly what is happening ? When you push a button before calling, you should never be able to come out with a different number.
Also please mention exact IOS used and phonw firmware.
smallrain_2 Mon, 02/18/2008 - 11:45
Here are phone loads and IOS info:
tftp-server p00403020214.bin
tftp-server flash:P00308000400.bin
tftp-server flash:P00308000400.loads
tftp-server flash:P00308000400.sb2
tftp-server flash:P00308000400.sbn
telephony-service
load 7931 P00308000400
max-ephones 30
max-dn 30
timeouts interdigit 3
dn-webedit
time-webedit
transfer-system full-consult
"flash:c2800nm-advipservicesk9-mz.124-15.T3.bin"
The dial-peers and voice-ports config are already posted in the previous messages.
And here is what happen:
1. line number are successfully configured on the phone
2. picking each line give a proper dial-tone
3. calling out is not a problem and all calls went through
4. only problem was router/ccme was using randon line to call out. In other words, when line 1 was picked on the phone and outbound calls was made, router used either line 1 or other lines.
we have same destination-patter (9.T) on all dial peers. Using preference make consistant outgoing call from line/dial-peer with lowest preference if line is avaialbe and I beleive that is what supposed to be.
paolo bevilacqua Mon, 02/18/2008 - 13:47
  • Hall of Fame,
    Founding Member
Yes, that's the way it's supposed to be. Now, there is a simpler way to simplify configuration, trunk-group. Under the voice port, assing a trunk-group. Reference this trunk-group instead of port under DP. This way you can reduce sensibely the number of DP. The if you still want an order of preference, this is also possible.
Latest recommendation, get ISDN if possible at all, and you will be enjoying a set of new features.
