Limit wri erase from TELNET only
Feb 17th, 2008
Can I configure an ACS to limit the commands available to Telnet sessions without affecting console commands. I.E. I want to stop commands such as WRI ERASE from being run from Telnet
royalblues Mon, 02/18/2008 - 02:28
  • Green, 3000 points or more
You can either remove the AAA authentication & Authorization from the console or define 2 seperate aaa groups on the device, one for console and one for telnet.
The commands can then be resticted/made available as required
Narayan
r404827 Wed, 02/20/2008 - 14:19
Thanks, I realy do not want to remove AAA from the console port.
When you say define two seperate gropups on the device, is this the router / switch or the ACS box. Sorry I am new to AAA configs.
Kind Regards
Paul
