slow gui interface on VPN Concentrator 3000
Feb 18th, 2008
Hello, some of users are reporting slow gui user interface on VPN Concentrator, is there anyone who had the same or similar problem before ??
best regards
Overall Rating: 4 (1 ratings)
JORGE RODRIGUEZ Mon, 02/18/2008 - 10:29
  • Green, 3000 points or more
When you say gui are you refering to VPN admin gui.. I have not experience such but in your case I would check physical connections of the inside interface, perhaps there may be duplex missmatch in its switch port connection causing packets drops and slowing your gui connections.
Rgds
Jorge
050878james Mon, 02/18/2008 - 10:34
Hello, thank you for reply !
Well I mean the GUI web based admin for VPN Concentrator 3000, just as ASDM for Cisco ASA 55xx...
It happens just somethimes, but being more often in last weeks. When I click on one of the links it can be opened in couple sec as normal or about 2-3 min.
I am connected via CAT5 trough LAN only, no dial-u or remote access from WAN area.
Tryed a reboot but no help :(
