royalblues Mon, 02/18/2008 - 02:37
  • Green, 3000 points or more
I dont think it is possible
Typing the command everytime is not difficult either :-)
shivlu jain Mon, 02/18/2008 - 04:54
  • Silver, 250 points or more
you can try one thing that bind the term mon on with the exec and try to add with the telnet. Means when the telnet session will be opened it will run the command automatically.
regards
shivlu
