02-18-2008 04:44 AM - edited 03-05-2019 09:13 PM
I'm using the Cisco QoS Baseline with an untrusted device with a softphone. Here are the class-maps and policy.
ip access-list extended SOFTWARE-BASED-ENDPOINT-SIGNALING
permit ip any any dscp cs3
ip access-list extended SOFTWARE-BASED-ENDPOINT-VIDEO
permit ip any any dscp af41
ip access-list extended SOFTWARE-BASED-ENDPOINT-VOICE
permit ip any any dscp ef
class-map match-all SOFTWARE-BASED-ENDPOINT-VIDEO
match access-group name SOFTWARE-BASED-ENDPOINT-VIDEO
class-map match-all SOFTWARE-BASED-ENDPOINT-VOICE
match access-group name SOFTWARE-BASED-ENDPOINT-VOICE
class-map match-all SOFTWARE-BASED-ENDPOINT-SIGNALING
match access-group name SOFTWARE-BASED-ENDPOINT-SIGNLAING
policy-map SOFTWARE-BASED-ENDPOINT
class SOFTWARE-BASED-ENDPOINT-VOICE
police 128000 8000 exceed-action drop
class SOFTWARE-BASED-ENDPOINT-VIDEO
police 50000000 8000 exceed-action policed-dscp-transmit
class SOFTWARE-BASED-ENDPOINT-SIGNALING
police 32000 8000 exceed-action policed-dscp-transmit
class class-default
set ip dscp default
all basic checks such as mls qos enabled etc checked.
The problem is that no packets are matched on the ingress policy from any softphone client.
Service-policy input: SOFTWARE-BASED-ENDPOINT
Class-map: SOFTWARE-BASED-ENDPOINT-VOICE (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name SOFTWARE-BASED-ENDPOINT-VOICE
Class-map: SOFTWARE-BASED-ENDPOINT-VIDEO (match-all)
0 packets, 0 bytes
Match: access-group name SOFTWARE-BASED-ENDPOINT-VIDEO
Class-map: SOFTWARE-BASED-ENDPOINT-SIGNALING (match-all)
0 packets, 0 bytes
Match: access-group name SOFTWARE-BASED-ENDPOINT-SIGNLAING
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
Do i need to configure sdm prefer routing for this to function? The switch is running 12.2.40 enhanced image.
interface FastEthernetx/x/x
switchport access vlan x
switchport mode access
switchport voice vlan y
mls qos trust device cisco-phone
service-policy input SOFTWARE-BASED-ENDPOINT
end
02-22-2008 08:12 AM
Make sure you followed all the necessary steps. Use this catalyst 3750 Switch Software Configuration Guide(Configuring QoS) document.
02-22-2008 08:47 AM
Are you positive the "softphone" uses the DSCP markings you expect?
02-24-2008 01:21 PM
Yes. I have since found out from Cisco that the show policy-map command does not work at all on the 3750 platform. In addition access-lists will also never be matched in this manner since "the processing is in hardware".
So why the SRND documentation provides configuration that cannot be verified is very strange. They say you should use the 'show mls qos interface statitics' command but that increments if you have a service-policy applied, trust or nothing so is basically useless!
03-10-2008 12:29 PM
I have ran into this as well.
You can use show mls qos interface
Matt
03-10-2008 02:47 PM
Actually its worse than you think. The 'show mls qos stats
