MGCP PRI Outbound Busy
Feb 18th, 2008
I did a firmware upgrade which went without issue. However, after it was done, the facility stated that they were not able to make outbound calls, inbound worked fine.
I did a no mgcp, and that resolved the issue. My question is: Should I treat this as coincidence or could it have to do with the firmware upgrade having an adverse affect on the callmanager?
The upgrade consisted of 141 phones.
Jaime Valencia Mon, 02/18/2008 - 12:34
i don't believe the issue was due to the firmware since they run over a whole different protocol, phones SCCP, GW MGCP.
What was the status of the GW under CUCM? registered, unregistered, unknown?
Did you gather a debug isdn q931 to look at the reason code for the disconnect?
