Faxing using the fxs port UC500
Feb 18th, 2008
Hello
I would like to use one FXS port for faxing. Fax starts to dial out but gives a communication error after some time.
Inbound to the fax routes to the voicemail.
Kind regards,
Overall Rating: 3.5 (2 ratings)
paolo bevilacqua Mon, 02/18/2008 - 09:31
  • Hall of Fame,
    Founding Member
try:
network-clock-participate wic 1
network-clock-select 1 BRi 1/1/0
Is it not possible to have fax call routed automatically inbound to FXS, you have to dedicate an external number for that.
roydennemans Tue, 02/19/2008 - 07:03
Hello, the network-clock settings work for outbound faxing.
How do I set a direct external number from BRI number block to the FXS port?
paolo bevilacqua Tue, 02/19/2008 - 07:08
  • Hall of Fame,
    Founding Member
I remember you have the ports in so called "sccp mode". So configure as it if was an extension.
roydennemans Tue, 02/26/2008 - 00:52
I can not get it stable. I will try to use an ATA instead.
Thanks for your help
roydennemans Fri, 02/29/2008 - 08:01
Hello again,
TAC told me it's possible to use the FXS without ATA, I would need to use:
network-clock-participate wic 3
network-clock-select 1 BRI0/1/0
voice service pots
text relay fax rate disable
fax rate disable
Change FXS to
type ata instead of anl
However, I get the following error (busy tone)
on incoming:
Feb 29 15:35:35.139: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
Feb 29 15:35:35.223: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x2E
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '2*********'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '2*********'
Feb 29 15:35:35.235: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xAE
Channel ID i = 0x89
Exclusive, B1
Feb 29 15:35:35.251: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xAE
Cause i = 0x8091 - User busy
Feb 29 15:35:35.347: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x2E
Feb 29 15:35:35.351: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA
E
Feb 29 15:35:45.383: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Feb 29 15:36:02.607: ISDN BR0/1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Feb 29 15:36:02.659: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to down
Outgoing works fine!
paolo bevilacqua Fri, 02/29/2008 - 08:40
  • Hall of Fame,
    Founding Member
That depends by the how numbers are set, for some reason the cme cannot associate the called number to your FXS extension.
metalium2007 Fri, 02/29/2008 - 09:52
  • Bronze, 100 points or more
Can you repeat what the problem is? I had some issues with faxing with an uc500 and solved them...maybe i can help you.
Met.
roydennemans Thu, 03/06/2008 - 01:39
I can not "call" the FXS ports. I have connected (for troubleshooting) a regular analog phone which (same as the fax) can call out, but it does this with a anonymous number.
If I call the extension from another Cisco IP Phone I receive voicemail or when this is not configured busy tone. I can call other Cisco IP phone extensions, but it does this (again) with a anonymous number
Almost default config from Cisco still does not work, (below)
ephone-dn 5
number 301 no-reg primary
label 301
description PhoneA Analog
name PhoneA Analog
call-forward busy 333
call-forward noan 333 timeout 10
ephone-dn 6 dual-line
number 302 no-reg primary
label 302
description PhoneB Analog
name PhoneB Analog
ephone-dn 7 dual-line
number 303 no-reg primary
label 303
description PhoneC Analog
name PhoneC Analog
ephone-dn 8 dual-line
number 304 no-reg primary
label 304
description PhoneD Analog
name PhoneD Analog
ephone 1
device-security-mode none
video
mac-address ****.8EB0.0000
username "PhoneA"
type anl
button 1:5
ephone 2
video
mac-address ****.8EB0.0001
username "PhoneB"
type anl
button 1:6
ephone 3
video
mac-address ****.8EB0.0002
username "PhoneC"
type anl
button 1:7
ephone 4
video
mac-address ****.8EB0.0003
username "PhoneD"
type anl
button 1:8
mamkreutz01 Mon, 06/02/2008 - 05:06
Hi there roy,
I am having this similar problem on two locations with an UC520. I can configure the dial-peer so that there can be send faxes out but then nothing gets in. When i make the configuration for the incoming then nothing can be send out. I also have the problem that i cannot call the analogue extensions.
